Configuration Flash Memory For Cyclone IV E - Military Grade?
It should be able to work but it can only support ASx1. Please refer to https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/component/2018/how-do-i-enable-micron-s-mt25q-support-for-eol-of-epcq---256mb--.html on how to enable it. Please follow the step which is the same as Cyclone 10 LP device.
- JArti26 years ago
Can you please share a schematic, and/or some documentation explaining how to connect up the MT25Q device to the Cyclone IV E?
There are some differences in the pin names, so I'm not sure which pins to connect up to get a similar functionality as the Intel/Alter Configuration Flash Memory devices, which I have used in previous designs.
Thanks!
John
- JArti26 years ago
In the attached document, it doesn't say Cyclone IV E is compatible with MT25Q memory.
