JArti2
6 years agoConfiguration Flash Memory For Cyclone IV E - Military Grade?
I'm designing a military application using a Cyclone IV E device (EP4CE55F23A7N - automotive grade), but can't seem to locate an automotive grade configuration flash memory chip. I need one that goes...
JArti2
6 years agoCan you please tell me if MT25QL is compatible with the Cyclone IV E, and if Quartus Prime Standard will recognize it.
The reason I ask is because in the past, I tried to use a Flash memory from another company and I tried programming the configuration into the device in Quartus using a USB Blaster II, and had some issues recognizing the ID of the memory.
Also, can you indicate whether I can use AS mode with any of their chips?
Thanks for you responses!
