15 years agoCommunication PC-De0 Nano
Hello everyone, I need to make a GUI that could communicate between pc and my De0 nano. I could make the GUI with QT but I don't know how the communication work. I am aware that every time I c...
15 years agoHello Dave,
I think I am really hopeless here with vji. Have you already finished the tutorial already? Please finish it. I really need everyone's help. I found an example about vji from pdf you gave. Here is the code: module counter (clock, my_counter); input clock; output [3:0] my_counter; reg [3:0] my_counter; always @ (posedge clock) if (load && e1dr) // decode logic: used to load the counter my_counter my_counter <= tmp_reg; else my_counter <= my_counter + 1; // Signals and registers declared for VJI instance wire tck, tdi; reg tdo; wire cdr, eldr, e2dr, pdr, sdr, udr, uir, cir; wire [1:0] ir_in; // Instantiation of VJI my_vji VJI_INST( .tdo (tdo), .tck (tck), .tdi (tdi), .tms(), .ir_in(ir_in), .ir_out(), .virtual_state_cdr (cdr), .virtual_state_e1dr(e1dr), .virtual_state_e2dr(e2dr), .virtual_state_pdr (pdr), .virtual_state_sdr (sdr), .virtual_state_udr (udr), .virtual_state_uir (uir), .virtual_state_cir (cir) ); // Declaration of data register reg [3:0] tmp_reg; // Decode Logic Block // Making some decode logic from ir_in output port of VJI wire load = ir_in[1] && ~ir_in[0]; // Bypass used to maintain the scan chain continuity for // tdi and tdo ports bypass_reg <= tdi; // Data Register Block always @ (posedge tck) if ( load && sdr ) tmp_reg <= {tdi, tmp_reg[3:1]}; // tdo Logic Block always @ (tmp_reg[0] or bypass_reg) if(load) tdo <= tmp_reg[0]; else tdo <= bypass_reg; endmodule I have questions about this example. 1. From the pdf, I can read that tck is the clock used for shifting the data in and out on the TDI and TD0 pins. In the example above, what is actually "always @ (posedge tck)"? What I don't understand is how it become a "clock"? It doesn't even wired to the "input clock" of "module counter". Is it just "automatically has the same clock as De0 nano has? 2. What does the following code mean? if ( load && sdr ) tmp_reg <= {tdi, tmp_reg[3:1]}; Why is "tmp_reg[3:1]" instead of "tmp_reg[3:0]"? What is the value of "tmp_reg[0]" then? I know that sdr will become 1 when DR scan shift operation occurs or tdi is valid. Load will be 1 if ir_in[1] = 1 and ir_in[0] = 0. (Please correct me if I'm wrong) 3. What happens here? always @ (tmp_reg[0] or bypass_reg) if(load) tdo <= tmp_reg[0] else tdo <= bypass_reg; I take it that "tmp_reg[0] or bypass_reg" are values that changing. But it doesn't seems that "tmp_reg[0]" get value from anywhere. Thank You Dave. Gunardi PS. please finish your tutorial. I do need it. Thank you for your effort so far.
