15 years agoCommunication PC-De0 Nano
Hello everyone, I need to make a GUI that could communicate between pc and my De0 nano. I could make the GUI with QT but I don't know how the communication work. I am aware that every time I c...
15 years agoHello Dave,
I prefer the solution that is onboard solution. I mean why should I buy a new device if there is a solution that already onboard. I think I prefer to use virtual jtag. As a matter of fact, I found 2 solutions: 1. Buy a usb-ttl 3.3V and connect it to I/O port of De0Nano FPGA board. Of course using this solution I need to write a serial communication protocol. 2. Use another microcontroller board and connect the uc and fpga I/O pin. The protocol between both of them could be serial or paralel protocol(depending on how much pin I would like to use or how much pin is available). At least use 2 wire, if using I2C. The fpga act as master and uc act as slave that transmit or receive data to pc. I find that both solutions is a waste of resource(my professor think so too especially solution no 2) because I think the De0 nano has to be able to transmit and receive data to pc someway. Thank you so much Dave. Wish you could finish it at once. :)
