14 years agoCommunication / USB Blaster Like RS232
I have a DSP Development Kit Cyclone III, but it doesn't have a RS232 and i need comunicate with nios to acces a data for the PIOs it's posible use the Physical USB-Blaster(No the Embedded) to comuni...
11 years ago --- Quote Start --- I don't know how to start --- Quote End --- Go through a NIOS II tutorial and create a "Hello World!" example. Have that example send data to a regular UART, and connect your FTDI interface to those pins. At that point you have a communications channel between your FPGA NIOS II processor, and your PC. Modify the NIOS II code so that it receives commands or data over the serial port, and then processes that data, eg., write to memory or read from memory. Write some MATLAB code to create and send the serial commands to the NIOS II processor, and then parse the response. Once you have the ability to write and read FPGA memory from MATLAB, you can then modify your FPGA code to add custom logic, eg., an FFT, and then you can send data to memory, program a DMA controller to stream it to the FFT, and stream the result back to memory, and once the FFT completes, you can read the destination memory from MATLAB and compare the result to the FFT model. Cheers, Dave
