vietvu1912
5 years agoCOMBINE ELF FILE INTO SOF FILE
I have some problems when I try to combine elf file into sof file.
1, I use "sof2flash" but I get a message that: "unrecognized device family in SOF". Does this command "sof2flash" not su...
vietvu1912
5 years agoThanks for your support. This problem has solved. But I have new problem when I try to run C file in fpga Nios II. I receive a error message: "Connected system ID hash not found on target at expected base address". I search to solve this problem, and I have added "System IP Peripherial" IPcore, but this problem can't solve. Can you support me to solve this? Thanks.
my project has attached below:
