vietvu1912
5 years agoCOMBINE ELF FILE INTO SOF FILE
I have some problems when I try to combine elf file into sof file.
1, I use "sof2flash" but I get a message that: "unrecognized device family in SOF". Does this command "sof2flash" not su...
NurAiman_M_Intel
5 years agoHi,
What is the Quartus version that was used? I would recommend to used the latest version.
Due to a problem in the Intel® Quartus® Prime Design Software version 17.1 and earlier, the sof2flash utility may fail to work with EPCQ device in Intel® Arria® 10, Intel® Cyclone® 10 and Intel® Stratix® 10 designs. You can also view the workaround/Fix from our KDB below:
Aiman
