Clock Pins for Arria 10 SoC Development Kit
Yes, this is what I am using. Perhaps the pin I am referring to is connecting to the fmcdaq2 board I have, and it is providing that signal.
I have been looking at the pinout file and the user guide of this development kit however the user guide isn't exactly as clear as it could have been, and the pinout is some sort of an alien language. Can you help me out and give me some pin that actually has at least 135 MHz frequency? It's fine if it's 300, 500, 750MHz or whatever, as long as it s more than 135MHz.
Hi there
If you check on "The Clock Control" section in https://www.intel.com/content/www/us/en/programmable/documentation/iga1434736665480.html#iga1439246083721, you are able to set the freq through the apps.
You can check on the schematic for the connection of Si5338 to the FPGA here:
Eng Wei
- GSagl15 years ago
Yes, except those apps do not work with Quartus 17.1. They apparently work with 15 something.
- EngWei_O_Intel5 years ago
Hi there
I am not sure if there is any library differences from version 15.1 to 17.1. So, are you able to work with it on 15.1, which according to the readme file, this is the Quartus version where the ref design is built up with.
Eng Wei
- GSagl15 years ago
I actually have Quartus 17.1 on my setup. And I have tried with 17.1 but there were some errors that popped up on screen even though I did exactly as it was said in the guide. I might have to try with 15.1, however, other things might break. And also on this forum there were some posts saying it had to be 15.1, so I think it really does not work with other versions. Aren't there any other clock pins?
