14 years agoChanging the degrees the BeInMotion kit rotate
So far I'm new in programming FPGAs and using the Quartus , Qsys and Nios. I tried to change all the values in the void turn_left() but returned empty handed. So far I'm grasping the basics but i'm pretty it is in that function. I want it to rotate from 90 degrees to around 45 deg. so that it will be smoother. Here's the code
int turn_left() { int dc_m1_pwm_duty = dc_m1_pwm_freq/4; int dc_m2_pwm_duty = dc_m2_pwm_freq/4; dc1_cmp = 1; dc2_cmp = 1; IOWR(IR_RX2_BASE,0x00,0); IOWR(IR_RX1_BASE,0x00,0); IOWR(DC2_PWM2_BASE+0x08,0,0); IOWR(DC1_PWM1_BASE+0x08,0,0); IOWR(DC2_PWM1_BASE,0,dc_m2_pwm_freq); IOWR(DC2_PWM1_BASE+0x04,0,dc_m2_pwm_duty); IOWR(DC1_PWM2_BASE,0,dc_m1_pwm_freq); IOWR(DC1_PWM2_BASE+0x04,0,dc_m1_pwm_duty); IOWR(IR_RX2_BASE,1,722); IOWR(IR_RX1_BASE,1,722); IOWR(IR_RX2_BASE,0x00,1); IOWR(IR_RX1_BASE,0x00,1); IOWR(DC1_PWM2_BASE+0x08,0,1); IOWR(DC2_PWM1_BASE+0x08,0,1); while(1) { if(( dc1_cmp ==0 ) && (dc2_cmp ==0 )) return 0; else { usleep(90000); dc_m1 = IORD(IR_RX1_BASE,1); dc_m2 = IORD(IR_RX2_BASE,1); i = dc_m1-dc_m2; j = dc_m2-dc_m1; if(i > 5) { if(dc_m2_pwm_duty >= 100) dc_m2_pwm_duty-=50; if(dc_m1_pwm_duty < 850) dc_m1_pwm_duty+=50; IOWR(DC2_PWM1_BASE+0x04,0,dc_m2_pwm_duty); IOWR(DC1_PWM2_BASE+0x04,0,dc_m1_pwm_duty); } else if(j > 5) { if(dc_m1_pwm_duty >= 50); dc_m1_pwm_duty-=50; if(dc_m2_pwm_duty < 1700) dc_m2_pwm_duty+=50; IOWR(DC2_PWM1_BASE+0x04,0,dc_m2_pwm_duty); IOWR(DC1_PWM2_BASE+0x04,0,dc_m1_pwm_duty); } } } } Hope someone and I'll appreciate it. Thank you in advance.No RepliesBe the first to reply
