MSale2's avatar
MSale2
7 years ago
[Case:567384] California 65 information
[Case:567384]
Please help me with the following points:
- According to the attached Material Declaration "en6337qi_20190718233352_v1.xml" there are one or more substance "Carbon Black@Ni@NiO"from the prop 65 chemical list found in this part "EN6337QI" but we need to confirm if the substances for each component are above or below the safe harbor level or if you follow with prop 65 requirements and provide (clear and reasonable warning) for the products that contain prop 65 substances list or not.
- According to the attached Material Declaration "epm1270f256i5n_20180720203830_v1.xml" there are one or more substance "Carbon Black@Arsenic@Ni"from the prop 65 chemical list found in this part "EPM1270F256I5N" but we need to confirm if the substances for each component are above or below the safe harbor level or if you follow with prop 65 requirements and provide (clear and reasonable warning) for the products that contain prop 65 substances list or not?
1 Reply
