SRedd11
7 years agoCan we send memory read-write TLP to PCIE Cyclone 4 GX Board using altpcie_demo_64 application obtained in kit?
If possible, how should i do simple read-write, when i run , run read or run write in the altpcie_demo_64 application, application is crashing.. Please help me.
Nathan_R_Intel
Contributor
7 years agoHie,
The altpcie_demo_64 is only to be used with Windows. Are you using Windows OS or Linux? The application itself only performs MWr and Mrd about 10-25 times.
You should also specify the BDF correctly (per your windows system) to avoid the application from being crashed. Please check if you are using Windows OS and specified the BDF correctly.
Nathan
