patrickk
6 years agoCan the Stratix-10 SOC Dev Kit's DDR4 SODIMM memory can be upgraded from 16GB to 32GB?
My question is whether the Stratix-10 SOC Dev Kit's DDR4 SODIMM memory card can be upgraded from 16GB to 32GB?
The Dev Kit currently has a 16GB (x72 w/ ECC) DDR4 SODIMM memory card (Micron MTA18ASF...
- 6 years ago
Hi Sir,
Yes, it is upgradable since the A[16] is connected to the board. Recently I am also upgrading the DIMM from 16GB to 32GB on the other boards. The changes are only open to the GUI, change the address pin setting, re-generate. Add the location assignment for the A16. The design is work now!
Anyway, please be reminded to review the timing parameter and see if it still the same.
BoonT_Intel
6 years agoSorry, forgot to mention, the data width at the local interface (avmm) might increase. However, I think it is still working if you did not change anything (the additional MSB bit let floating)
