Can the Stratix-10 SOC Dev Kit's DDR4 SODIMM memory can be upgraded from 16GB to 32GB?
- 6 years ago
Hi Sir,
Yes, it is upgradable since the A[16] is connected to the board. Recently I am also upgrading the DIMM from 16GB to 32GB on the other boards. The changes are only open to the GUI, change the address pin setting, re-generate. Add the location assignment for the A16. The design is work now!
Anyway, please be reminded to review the timing parameter and see if it still the same.
Hi BoonT,
Thanks for the good news that the memory can be upgraded from 16GB to 32GB.
Our distributor, Arrow, let me know that Micron recommends the B2 rev of the 32GB DDR4 SODIMM part I referenced. This part is P/N MTA18ASF4G72HZ-2G6B2, and is still introductory. Once we obtain the 32GB parts, we will upgrade our Stratix-10 SOC Dev Kits.
Thanks very much, Patrick
