Can I use GXB PIN of Stratix 10 as a pure data line?
I was able to assign the pin to GXB pin by assigning IO standard as High Speed Differential IO. Attached is the design.
- WKUAN5 years ago
Thank you very much, I have download the file, and get this error when i try to open the project
Info: Running Quartus Prime Shell
Info: Version 16.1.0 Build 196 10/24/2016 SJ Standard Edition
Info: Processing started: Fri Aug 20 13:43:22 2021
Info: Command: quartus_sh --restore -output G:/PROJECT/28GSPS/xvcr_bypass_21_1_0_169_restored/ -no_overwrite G:/PROJECT/28GSPS/xvcr_bypass_21_1_0_169.qar
Info: Quartus(args): -unqar -output G:/PROJECT/28GSPS/xvcr_bypass_21_1_0_169_restored/ -no_overwrite G:/PROJECT/28GSPS/xvcr_bypass_21_1_0_169.qar
Info: qar.tcl version #1
Error: Failed to restore G:/PROJECT/28GSPS/xvcr_bypass_21_1_0_169.qar
Error (23031): Evaluation of Tcl script c:/intelfpga/16.1/quartus/common/tcl/apps/qpm/qar.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 4804 megabytes
Error: Processing ended: Fri Aug 20 13:43:24 2021
Error: Elapsed time: 00:00:02
Error: Total CPU time (on all processors): 00:00:02Have I lost any file?
