PYtte
7 years agoCan I inteface the Ethernet PHY on DE10 Nano directly from the FPGA?
I want to test some Ethercat IP:s on a DE10 Nano board and need two Ethernet interfaces. I would like to use the one already on the board but it seems it only interfaces through the HDS. I will add...
PYtte
7 years agoOk thank you for your response. I was hoping it was using some of the pins that could be loaned to the FPGA.
I will have to add a PHY externally then to connect to GPIO for the FPGA.
Br
PYtte.
