sabo's avatar
sabo
6 years ago
Can I calculate or measure how Smart-VID reduces the device's supplied power?
Hi.
I use the FPGA Board of Stratix®10 devices for our projects.
This board is Intel® Stratix® 10 MX FPGA Development Kit(DK-DEV-1SMX-H-A) and Stratix®10 device is 1SM21BHU2F53E1VG.
Running the BTS(Board Test System) to monitor its power information is successful under our development environment.
And now, I want to know how Smart-VID reduces the device's supplied power using BTS or anything.
I checked the document is the user guide of FPGA Development Kit(UG-20151 | 2020.06.15).
In Figure 3, I found the SW1 is installed for PMBus Control.
Although settings of SW1 is a default position, can I monitor the supplied power with disabled Smart-VID using changed SW1 settings?
If the Smart-VID does not run under disable Smart-VID, can I calculate how Smart-VID reduces the supplied power?
  • EngWei_O_Intel's avatar
    EngWei_O_Intel
    Hi 山崎
    Thanks for your inquiry.
    If the Smart-VID is disabled, the power reduction of supplied power will not be enabled.
    Eng Wei
      EngWei_O_Intel
      Hi 山崎
      We do not receive any response from you to the previous reply that have been provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
      Eng Wei
      • sabo's avatar
        sabo
        Hi Eng Wei
        Thanks to your reply, my concern was well solved.
        I hope you don't mind if I ask for help again in the future.
        Thank you.
