15 years agoC4GX kit dev + TSE without external memory
Hi all, I got a new mistake. I start with the board update portal design from altera. I don't understand why in this design there is a big onchip memory and SSRAM. Can someone explain...
14 years agoHi all,
I was very busy and know i can share you my little experience. I ask to the altera support and the response is not very accurate. In according to altera support is better to don't use QSYS and when you start from an design example to don't modify the SOPC system even if you don't use some peripherals. For me it works but the response it is not what I expect. thanks.
