15 years agoC4GX kit dev + TSE without external memory
Hi all, I got a new mistake. I start with the board update portal design from altera. I don't understand why in this design there is a big onchip memory and SSRAM. Can someone explain...
15 years agoThanks for the picture but I can't see anything it's too small.
I found something interresting, the sgdma's (rx and tx) are connected to the uas port of the ssram and ext_flash. I've started this test with the original project. I disconnect rx and tx sgdma from ext_flash. Recompile and test ----> don't work and stuk like usual (wait descriptor chain). I go back to Qsys and make ctrl+z to have my connection restored. Recompile and test ----> don't work too, same problem. Interresting. I investigate.
