HZhen21
6 years agoBroken Pins Determination?
Hi, I am using Cyclone 10LP for SPI communication between PIC24 and this FPGA. I accidentally assigned same trace ports, SPI MOSI from PIC24 to Cyclone 10LP, both as output ports on both side. After ...
- 6 years ago
Hi Hao Zhen,
1 of the most easiest way is to toggle the output pin and then measure the pin using ossilloscope. If the VIH and VOH is as expected, then it is not broken.
Thank You.
YuanLi_S_Intel
6 years agoYes sir. If it can be. By right it shouldnt have any problem on the pin.
HZhen21
6 years agoThanks a lot!
