15 years agoBoard Test System
Hi Dear I want to run "Board Test System", but when run this, this message shown to me: "Connecting to the target... java.lang.Exception: No USB Blaster detected. Please check connections and ...
15 years agoI am assuming you are running on a real windows rather than a virtual one - some virtual layers have problems with USB which stops it working
The first thing to check here is that the cable is showing up in the device manager - if it is not then find the unknown device, right click on it and reinstall the driver from the quartus/drivers directory After that, check what `jtagconfig` returns - it should find your cable. Good luck
