Board Test System does not work with Arria 10 SoC
Hi
Could you help try. Don’t turn off the clock GUI setting, just key in the desired clock frequency in clock GUI software and click the “set” button. Then leave the clock GUI software as it’s.
That really wouldn't work? To use the GUI, you have to program the FPGA with bts_config.sof first. So if I set the clock with the GUI, then if the board is turned off and on again, the FPGA and the GUI would lose the connection.
And even if that would work, it's not really a concrete solution, because the pc could reboot itself, and even if that wasn't an issue, I can't do that. I have Windows10 on my setup and I work remotely. I would need to change windows10 to ubuntu in order to be able to do that, which will take even more work and is not desired.
