15 years agoBemicro SDK 80 I/O pins from edge connector
Hi, I would like to know how is the compiled .SOF file provided in the lab material uses the 80 pins edge connector. Because i can see that, Eclipse IDE recognizes 2 32bits GPIO being used in t...
15 years ago --- Quote Start --- You'd have to look at the pin assignments for the project, and then compare that to the schematic. Page 7 of the schematic shows that there are GPIO pins P1 to P60 connected to the 80-pin connector. --- Quote End --- I've tried that, non of them are configured to be output, all inputs... --- Quote Start --- Useless for projects that need the SDRAM, but not entirely useless :) --- Quote End --- Which means i cant really use NIOS2 design... such a nicely designed FPGA, what a waste.:( --- Quote Start --- Why not download the evaluation version of the controller (from whoever it is that supplies it)? --- Quote End --- Tried that too.. they will only allow you to use it for 1 hour everytime you compile. I would much rather get a Terasic DE0-nano than Bemicro Nano, since they provide important IP cores. I found out, i could actually use the SDRAM controller that comes with SOPC builder, just a little timing configuration. Michael
