15 years agoBemicro SDK 80 I/O pins from edge connector
Hi, I would like to know how is the compiled .SOF file provided in the lab material uses the 80 pins edge connector. Because i can see that, Eclipse IDE recognizes 2 32bits GPIO being used in t...
15 years ago --- Quote Start --- I would like to know how is the compiled .SOF file provided in the lab material uses the 80 pins edge connector. --- Quote End --- You'd have to look at the pin assignments for the project, and then compare that to the schematic. Page 7 of the schematic shows that there are GPIO pins P1 to P60 connected to the 80-pin connector. There's a good chance the 32-bit GPIO ports are mapped to 1-32, and 33-60. --- Quote Start --- Without the SDRAM, the Bemicro SDK is pretty much USELESS. --- Quote End --- Useless for projects that need the SDRAM, but not entirely useless :) Why not download the evaluation version of the controller (from whoever it is that supplies it)? Cheers, Dave
