BillM256
5 years agobdf designs and connections between multiple bdfs
Issue: I want to design a fairly complex FPGA device using mostly .bdf schematics. Each schematic will be essentially a page in the overall multi-page system design and its documentation. Fo...
- 5 years ago
No, PD is a system design tool, where you add components (off-the-shelf IP or your own custom IP) and connect their interfaces together.
A PD system can be the top-level in a Quartus project or it can be instantiated lower down in the project hierarchy.
BillM256
5 years agoOk, I think I understand. I can use the Block/Schematic Editor to design a higher-level schematic that ties my desgin elements e.g., registers, together the way I used it at the low-level to combine primitives to create the registers. Right?
Many thanks,
Bill
- BillM2565 years ago
Hello again,
I've been playing w/Schematic/Block editor and am beginning to understand the relationship between .bdfs and .bsfs. I belive I'm back on track and will mark this as complete thanks to your help.
Bill
