Arthur_Davidov's avatar
Arthur_Davidov
5 years ago
ARRIA 10 U-Boot boot from QSPI - spi probe failed
I use with arria 10 dev kit and followed the tutorial Arria_10_SoC_45_Boot_from_QSPI
I prepared system for baremetal and skipped the sections to prepare:
  • kernel.itb - Linux kerned and device tree
  • core-image-minimal-arria10-rootfs.jffs2 -Linux rootfs
Than I programed:
cd $TOP_FOLDER/qspi_bin
~/intelFPGA_pro/20.4/nios2eds/nios2_command_shell.sh \
quartus_hps -c 1 -o e
quartus_hps -c 1 -o pv -a 0x0000000 u-boot-splx4.sfp
quartus_hps -c 1 -o pv -a 0x0100000 fit_uboot.itb
quartus_hps -c 1 -o pv -a 0x0300000 fit_spl_fpga.itb
As the result I get a "spi probe filed":
What is the problem? What it does mean?
BTW, I followed boot from SD card instructions (also for baremetal - without kernel and rootfs files) and success to boot.
  • MNoli2's avatar
    MNoli2
    https://rocketboards.org/foswiki/Documentation/BuildingBootloader#Arria_10_SoC_45_Boot_from_QSPI
    I skipped :
    cd $TOP_FOLDER/a10_soc_devkit_ghrd/software/bootloader/u-boot-socfpga
    ./arch/arm/mach-socfpga/qts-filter-a10.sh \
    ../../../hps_isw_handoff/hps.xml \
    arch/arm/dts/socfpga_arria10_socdk_qspi_handoff.h
    using, instead the git version of socfpga_arria10_socdk_qspi_handoff.h unmodified. My dev kit booted to u-boot and the kernel.
    Mike
  • AnilErinch_A_Intel's avatar
    AnilErinch_A_Intel
    Hi ,
    Good to see the community discussions.
    Please let us know if any further support is required in this issue.
    Thanks and Regards
    Anil
