arria 10 soc development kit fmc connector
We do have Arria 10 SoC Development Kit, according to the schematic both FMC are HPC, and even on board i have inspected it has same connector module, so those both are HPC- FMC.
I wanted to connect ft602 module to this development board, as the FT602 has LPC-FMC,
I couldnt connect it, Is there any other solution for these connection.
development board schematic link is
ft602 module schematic link is
http://www.ftdichip.com/Support/Documents/DataSheets/Modules/DS_UMFT602x%20module%20datasheet.pdf
development board user guide
even tho in development board user guide its mentioned as two FMC, one is LPC and other is HPC,
but the connector used for both are same, so when i google the connector "ASP-134486-01" its a FMC-HPC connector, So
Now How should i connect the FT602 module to this development board ??
1 Reply
- Deshi_Intel
HI,
Unfortunately Intel FPGA only sell dev kit board that comes with some default accessary daughter card board.
If you required something special like for instance HMC convertor daughter card then you may want to google to see if you are able to purchase from other HMC connector vendor
Thanks for your understanding
dlim
