Arria 10 Soc Dev Kit and LMK04828
I am not asking for a reference design or anything like that. Maybe I explained myself wrongly.
On the Arria 10 Soc Dev Kit board there is a LMK04828 from TI with a 122.88 MHz VCXO. The SPI interfacing this device is connected to one of the MAX5 CPLDs and, according to the user guide, it serves as a bridge from the dedicated USB connector. The user guide says this about the LMK04828:
(there should be an image here but in-line copy/paste doesn't seem to work). For more info:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-a10-soc-devkit.pdf
(page 54)
So I have 2 questions:
1) What software from TI (or anyone else) do I need to use to interface this chip on your reference board? I can't believe you have fitted a component on a board and not tested its functionality. The user guide doesn't specify anything and the MAX-V in between the FTDI and the LMK04828 can be doing anything. Is there some sort of UART built in interface at the MAX-V with command/address/data transfers?
2) Is there a way to access this chip from the HPS (probably not)?
Thanks in advance
I apologize for the misunderstanding.
1) I sent a zip file that should contain all the information regarding the usage of the clock cleaner to you via message. Can you check your inbox if you have received it?
2) I cannot confirm if the clock cleaner is accessible from the HPS, I did not found any information regarding this in our documentation and the file given.
Regards.
- vage6 years ago
I also need this information regarding the usage of the clock cleaner on the very same board. May I also have it please?
Many thanks and best regards.
- EBERLAZARE_I_Intel6 years ago
I have sent to you via message as well, check it out.
- DaveS4 years ago
May I also have the LMK04828 info for the A10 soc dev kit?
- Zbigniew_Szadkowski3 years ago
Could you send me any info and software to program LMK04828 on the Arria 10 SoC Development Kit
Zbigniew Szadkowski
- vage6 years ago
I'm on it right now.
Many thanks and best regards!
- JET602006 years ago
Contributor
Hi @EberL_Intel
We have an A10SOC Dev Board on hand, and I also need this LMK04828 materials regarding the usage of the clock cleaner on the board. May I also have this as well ?
Thanks and Best regards
Jet
- vage6 years ago
Hi Jet, let me know if you don't get feedback on this and I can try to find my copy. Best, Evangelos.
Contributor
many thanks @vage ,would you please send me a copy to email ( [email protected] ), Thanks a lot
Best Reagrds
- NZhan15 years ago
Hi EBERLAZARE_I_In
tel, We have the same request to change LMK04828's output clock, could you help to share the GUI or materials? Thanks!
- elabarge4 years ago
Hello, can you please send me the same zip file? I would also like to program the clock cleaner on my Arria 10 dev kit.
Elliott
- KeeganJ2 years ago
Could I also have whatever information was provided?
It seems that the SFP+ ports on this dev kit go to a transceiver bank which can receive two possible reference clocks.
One reference clock is from this clock cleaner and the other one from FMC. So if you want to use the SFP+ port you have to provide the correct reference clock through one of those two options. Does that sound correct?
I don't understand how more information was not provided in the user guide. Surely someone wants to use the SFP+ port?
