11 years agoArria 10 GX not recognized in lspci
Hi, I want to use an Arria 10GX FPGA for OpenCL programming, therefore I connect it to a PCI slot on a host machine. However, before I can do anything else, it is not listed by lspci. What ...
11 years agoThe PCIe HIP needs to be programmed with a bitfile and then the system needs to be rebooted.
If your Arria 10 card is already setup for OpenCL this would be in flash and would have happened when you powered up.
