9 years agoArria 10 GX Devkit Programming Issue
When a scan jtag chain is performed on the devkit (all dip switches on default) after an image other than the factory build is programmed to the A10, the configuration flash is no longer seen in the ...
9 years agoOh, I see what you mean. Usually (80% of the time?) I don't see the configuration flash when executing a JTAG scan--not sure why. Would it work to save the .cdf when you *can* see the config. flash and use that .cdf every time after that?
