9 years agoArria 10 GX Devkit Programming Issue
When a scan jtag chain is performed on the devkit (all dip switches on default) after an image other than the factory build is programmed to the A10, the configuration flash is no longer seen in the ...
9 years agoAre you plugging into the on-board USB-Blaster, using a USB-Blaster plugged into the JTAG port, or something else? When I use the on-board USB-Blaster I don't have problems--other than my USB cable falls out some times.
