9 years agoArria 10 GX Devkit Programming Issue
When a scan jtag chain is performed on the devkit (all dip switches on default) after an image other than the factory build is programmed to the A10, the configuration flash is no longer seen in the ...
9 years agoHi avivweinstein,
I have the same issue on the devkit. Actually, it's working sometimes, but on some fitting, the JTAG chain is broken... Did you find a solution? Regards, Lionel
