10 years agoArria 10 Dev Kit -- USB-Blaster flash programming instructions
Re: The Arria 10 GX Dev Kit Do instructions exist for programming the hardware1 area in flash with the usb-blaster? I need a faster way than: 1.) remove dev kit from PC 2.) ...
9 years agoHi,
I am new to Quartus Software and its workflow. Please bear with my question. I generated sof file and converted to pof file as mentioned above. I did not get any error while programming flash. I changed SW6 setting and also checked for SW5 in correct position. But it seems it did not work. My program was to blink one LED but instead it keeps blinking alternate user LEDS. Do we need to use Parallel Flash Loader IP Core to use CFI Flash on board? Any step by step tutorial will be great. Thanks and Regards, Parthiv
