10 years agoArria 10 Dev Kit -- USB-Blaster flash programming instructions
Re: The Arria 10 GX Dev Kit Do instructions exist for programming the hardware1 area in flash with the usb-blaster? I need a faster way than: 1.) remove dev kit from PC 2.) ...
10 years agoHi, I am assuming that you are talking about the EPCQ flash on the board - sorry if this is not correct, as I don't have this board - perhaps you can consider updating the flash image via UART? I believe I saw some design examples using Nios to handle that.
