JPeng7
8 years agoApply for FA of EP2C35F672I8N
Flex encountered 27pcs boards were functional failed board test station , device DC1807, Intel part#:MPN:EP2C35F672I8N. A-B-A swap test verified it is related with chips. Pls. kindly refer to att...
JPeng7
8 years agoHi, Chia
End customer is NOKIA, pls. kindly refer to below replies in yellow, thanks!
What kind of function can’t work normally?
--- The board simultaneously broadcasts one port of F2 transparent transmission data.
Did you encounter any open/short failure?
---Not found open/short failure.
Any abnormality on the power rail performance?
---Not found.
Any suspected failure pins?
---There are only two signals “HDRXD0_OHP_PGA, HDTXD0_OHP_PGA”,The FPGA pins “R5,AB4”
---Not found failure pins.
Jimmy +86 512 67868800 Ext:2132
