15 years agoAny low cost eval boar with USB blaster cable included?
Hi, I have several Altera dev. boards which I bought several years ago. Back in that time all programming was done via the ByteBlaster (parallel port) cable. When I moved to Vista 64 bits, se...
14 years ago --- Quote Start --- in my Windows 7 64bit configuration it is NOT detected when using the latest Quartus II software. Currently I'm using 11.0. --- Quote End --- I have Windows 7 64-bit and Quartus v11.0. I just checked, the device manager shows the Terasic USB-Blaster as an Altera USB-Blaster, and the 64-bit version of Quartus detects it fine. I also have Quartus 10.1sp1 on this machine. I forget which order I installed them. Once you get the USB-Blaster detected, try re-installing version 11.0, or 11.1. It could be a driver issue that is resolved by installing the older software. Cheers, Dave
