15 years agoAny low cost eval boar with USB blaster cable included?
Hi, I have several Altera dev. boards which I bought several years ago. Back in that time all programming was done via the ByteBlaster (parallel port) cable. When I moved to Vista 64 bits, se...
15 years agoOr you also have this one
http://www.entner-electronics.com/tl/index.php/eeblaster.html If you used the 10-pin header to connect your designs to the byte blaster then you should be able to plug the USB blaster instead without modification.
