9 years agoALTERA MAX 10 How to write custom ADC interface verilog code
Hello guys, I am new to FPGA though I have experience with verilog coding. I am working on a Project where I need to use the ADC of Max 10 at 1MSPS to measure an analog signal and send the b...
9 years ago --- Quote Start --- You don't say which MAX 10 development board you are using. Is it this one: https://www.altera.com/products/boards_and_kits/dev-kits/altera/max-10-fpga-development-kit.html ? The MAX 10 part on this board has an integrated ADC, it is not a separate part. The above page has pointers to the full board level schematic. If so, have you looked here and read these documents: https://www.altera.com/documentation/sam1393576011848.html ? PS If you are going to ask questions, you need to be REALLY specific about what boards/chips/software/etc you are using. We are not mind readers. --- Quote End --- The full description of the board is: Max 10M50DAF484C6GES Its the same one you have given in the link. Yes I went through the schematic and the User guide for ADC. The schematic doesnt really show the ADC chips output pins only the analog input pins are mentioned. I guess its because its integrated by I dont understand that how will I send e.g. clock to the ADC without knowing the PIN. The user guide gives description about the ADC modular IP but doesnt provide much detail to understand the full working of the IP core to manipulate it.
