15 years agoAltera DE2-115 compatibility with HSMC-ADC-BRIDGE
I've already got an Altera DE2-115 board and I'm planning to use it together with a high speed ADC EVM by Texas Instruments for a measurement application. I've found in the "All Daughter Cards" pa...
15 years agoHi Lorenzo,
--- Quote Start --- Clear and complete :) Thank you for your precious support, I've learned many useful things I could have hardly got without it. --- Quote End --- You're welcome. Since you are testing ADCs, you might find these interesting reading: http://www.ovro.caltech.edu/~dwh/carma_board/digitizer_tests.pdf (http://www.ovro.caltech.edu/%7edwh/carma_board/digitizer_tests.pdf) http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/lfsr_tutorial.pdf) http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-100paper_hawkins.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/esc-100paper_hawkins.pdf) Cheers, Dave
