15 years agoAltera DE2-115 compatibility with HSMC-ADC-BRIDGE
I've already got an Altera DE2-115 board and I'm planning to use it together with a high speed ADC EVM by Texas Instruments for a measurement application. I've found in the "All Daughter Cards" pa...
15 years agoFirst of all, thank you for replying: as you can see I really need help =)
I can compare pins of HSMC connector on p13 of DE2-115 schematics (am I on the wrong page?) with the ones of the male HSMC connector provided by the TI adapter: every pin on the TI board is also on the female HSMC on the DE2-115. Now, if I got what you said I have to verify if all of these pins come to the FPGA: the only ones I can't find on p25 are HSMC_SDA and HSMC_SCL. Are they the high-speed "trainscever lanes" you were referring to? (sorry, I'm a complete beginner with this kind of problems) Anyway, if they are I can read on DE2-115 User Manual that "Signals HSMC_SDA and HSMC_SCLK share the same bus with the respected signals I2C_SDA and I2C_SCL of the WM8731 audio chip": I looked for them on DE2-115 schematics and they're found on the Bank 8. Am I missing something? About the second answer you gave, I need to think a bit longer about it before probably asking some more =) Regards, Lorenzo
