Radhakrishnasai
5 years ago10M04DAF256I7G POF
Dear Team,
We are trying to load the logic into 10M04DAF256I7G( Max 10 ) in .sof format, FPGA is responding.
But if we try to load in .pof format there is no response from FPGA.
Can you pleas...
Radhakrishnasai
5 years agoHello,
Thanks for your inputs actually .pof is working fine after giving pullup at config done pin.
Now we are facing below issue,
For bank 1B , 2.5V supply is given, that means all IOs from bank 1B will operate at 2.5V. But if we give 3.3V signal on this bank 1B IO pins what may be happens.
is there any protection diodes will be there internally or any damage will be happening to the bank?
Radhakrishnasai V
EngWei_O_Intel
5 years agoHi Radhakrishnasai
You have to follow the requirement in Table 4 of https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_gpio.pdf base on your IO standard, else you might be facing functionality issue.
Eng Wei
