10M04DAF256I7G POF
By not able to program .pof, does this happened at stage where you are programming it using Quartus ? or boot up?
Is there any error message?
Aiman
- Radhakrishnasai5 years ago
Thanks for your inputs actually .pof is working fine after giving pullup at config done pin.
Now we are facing below issue,
For bank 1B , 2.5V supply is given, that means all IOs from bank 1B will operate at 2.5V. But if we give 3.3V signal on this bank 1B IO pins what may be happens.
is there any protection diodes will be there internally or any damage will be happening to the bank?
Radhakrishnasai V
- EngWei_O_Intel5 years ago
Hi Radhakrishnasai
You have to follow the requirement in Table 4 of https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_gpio.pdf base on your IO standard, else you might be facing functionality issue.
Eng Wei
