10G transceiver in S10MX
The 10G example design use only 1 lane. You might need to double-check which lane that you are actually connected from the board schematic. Perhaps, you may try to connect with a QSFP loopback module to ensure the design is working first before connecting with others.
Besides, you may start with the 10GBASE-R Ethernet design example, and use 322Mhz as a reference clock. See the link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20073.pdf
Regards -SK
- XNguy46 years ago
Thank for your reply.
Do you refer lane as channel? I modify the example design to support 4 channels, each channel 10G. I also tested the design with QSFP28 Port 0 and Port 1, but neither worked properly.
I already tested the network with an Arria 10 board beforehand. So I am pretty sure it was not the network issue.
My approach (B) is based on the document you have sent.
The Intel S10MX board only provide QSFP reference clock of 644.5312 MHz. That's why I modified the ref_clk settings in the PHY, ATX, and fPLL module to 644 MHz.PHY setting: modifychange CDR reference clock
ATX PLL setting: modify PLL auto mode reference clock
altera_xcvr_atx_pll_ip atx_pll_inst( .pll_refclk0(ref_clk_clk), .tx_serial_clk(tx_serial_clk), .pll_locked(atx_pll_locked) );fPLL setting: modify PLL integer mode reference clock
pll fpll_inst ( .pll_refclk0 (ref_clk_clk), .pll_cal_busy (), .outclk_div2 (core_clk_156), // 156.25MHz clock .outclk_div1 (core_clk_312), // 312.50MHz clock .pll_locked (core_pll_locked) );Top-level file
module altera_eth_top # ( parameter NUM_CHANNELS = 4, parameter DEVICE_FAMILY = "Stratix 10" )( input wire CLK_SYS_100M_P, input wire CLK_DDR4_COMP_P, input wire refclk_zqsfp0_p, input wire refclk_zqsfp1_p, input wire CPU_RESETN, output wire [NUM_CHANNELS-1:0] zqsfp0_tx_p, input wire [NUM_CHANNELS-1:0] zqsfp0_rx_p, output wire [NUM_CHANNELS-1:0] zqsfp1_tx_p, input wire [NUM_CHANNELS-1:0] zqsfp1_rx_p, output zqsfp0_1v8_modsel_l , output zqsfp0_1v8_reset_l , input zqsfp0_1v8_modprs_l , output zqsfp0_1v8_lpmode , input zqsfp0_1v8_int_l, output zqsfp1_1v8_modsel_l , output zqsfp1_1v8_reset_l , input zqsfp1_1v8_modprs_l , output zqsfp1_1v8_lpmode , input zqsfp1_1v8_int_l, inout zqsfp_s10_i2c_sda , output zqsfp_s10_i2c_scl ); wire ninit_done; assign zqsfp1_1v8_lpmode = 1'b0; assign zqsfp1_1v8_modsel_l = 1'b0; assign zqsfp1_1v8_reset_l = 1'b1; //CPU_RESETN && ~ninit_done; assign zqsfp0_1v8_lpmode = 1'b0; assign zqsfp0_1v8_modsel_l = 1'b0; assign zqsfp0_1v8_reset_l = 1'b1; // CPU_RESETN && ~ninit_done; assign zqsfp_s10_i2c_sda = 1'bz; assign zqsfp_s10_i2c_scl = 1'bz; wire core_clk_312; // LED wire [NUM_CHANNELS-1:0] block_lock_n; wire [NUM_CHANNELS-1:0] tx_ready_export_n; wire [NUM_CHANNELS-1:0] rx_ready_export_n; // debug clock wire core_clk_156; wire core_pll_locked_n; wire atx_pll_locked_n; wire [NUM_CHANNELS-1:0] avalon_st_rxstatus_valid_156; wire [NUM_CHANNELS-1:0][39:0] avalon_st_rxstatus_data_156; wire [NUM_CHANNELS-1:0][6:0] avalon_st_rxstatus_error_156; wire csr_rst_n; wire tx_rst_n; wire rx_rst_n; wire [NUM_CHANNELS-1:0] block_lock; wire [NUM_CHANNELS-1:0] tx_ready_export; wire [NUM_CHANNELS-1:0] rx_ready_export; wire core_pll_locked; wire atx_pll_locked; wire csr_clk; assign csr_clk = CLK_SYS_100M_P; assign block_lock_n = ~block_lock; assign tx_ready_export_n = ~tx_ready_export; assign rx_ready_export_n = ~rx_ready_export; assign core_pll_locked_n = ~core_pll_locked; assign atx_pll_locked_n = ~atx_pll_locked; // Reset Release module reset_release reset_release_inst( .ninit_done (ninit_done) ); altera_eth_10g_mac_base_r #( .NUM_CHANNELS(NUM_CHANNELS), .DEVICE_FAMILY(DEVICE_FAMILY) ) dut_inst ( .csr_clk (csr_clk), .csr_rst_n (CPU_RESETN && ~ninit_done), .core_clk_312 (core_clk_312), .tx_rst_n (CPU_RESETN && ~ninit_done), .rx_rst_n (CPU_RESETN && ~ninit_done), .ref_clk_clk (refclk_zqsfp1_p), .core_clk_156 (core_clk_156), // csr interface .csr_read (1'b0), .csr_write (1'b0), .csr_writedata (32'b0), .csr_readdata (), .csr_address (16'b0), .csr_waitrequest (), .tx_ready_export (tx_ready_export), .rx_ready_export (rx_ready_export), .block_lock (block_lock), .tx_serial_data (zqsfp1_tx_p), .rx_serial_data (zqsfp1_rx_p), .core_pll_locked (core_pll_locked), .atx_pll_locked (atx_pll_locked), .avalon_st_rxstatus_valid_156 (avalon_st_rxstatus_valid_156), .avalon_st_rxstatus_data_156 (avalon_st_rxstatus_data_156), .avalon_st_rxstatus_error_156 (avalon_st_rxstatus_error_156) ); endmoduleThanks
