N6000-PL is not showing up in 'lspci'
Hey,
I solved the "lspci" issue with a proper power boot sequence.
But now after checking in lspci and rebooting the system the error -
"pci 0000:01:00.0: AER: Error of this Agent is reported first"
Keeps popping up bootup.
Any idea as to what might be the issue?
Thank you,
Best Regards.
I'm Kian and will also be assisting you in this case.
I suspect the card needs to be programmed first . Have you done any programming to the card ?
Also I was looking up on the AER error and some mentioned about disabling the pcie power management might help (pcie_aspm=off) to resolve the issue AER: Error of this Agent is reported first
Quote"
This may be due to PCIe Active State Power Management that is transitioning the link to a lower power state and maybe causing the device to trigger these errors.
You could add this to "/etc/default/grub"
pcie_aspm=off
And
sudo update-grub
Kian
