If you’re itching to get your hands on the innovative features built into the new family of Intel® Agilex™ FPGAs like the second-generation Intel® HyperFlex™ architecture or the improved DSP capabilities including half-precision floating point (FP16) and BFLOAT 16 computational abilities, then consider the new Terasic DE10-Agilex Accelerator board. This PCIe card combines an Intel Agilex F-Series FPGA with four independent DDR4 SO-DIMM SDRAM sockets and two QSFP-DD connectors on a three-quarter length PCIe board.
The board’s host interface is a PCIe Gen 4.0 x16 port. Each SO-DIMM memory socket accommodates 8 or 16 Gbytes of DDR4 memory, for a maximum total SDRAM capacity of 64 Gbytes, and each QSFP-DD connector accommodates Ethernet transceiver modules to 200G. The board is available with two different cooling options: a 2-slot version with integrated fans or a single-slot, passively cooled version.
The Terasic DE10-Agilex Accelerator PCIe card combines an Intel® Agilex™ F-Series FPGA with four independent DDR4 SO-DIMM SDRAM sockets and two QSFP-DD connectors
The Terasic DE10-Agilex PCIe board supports the Intel® OpenVINO™ toolkit, OpenCL™ BSP, and Intel® oneAPI Toolkits used for developing code for myriad high-performance workloads including computer vision and deep learning. The Intel Agilex FPGA family delivers up to 40% higher performance1 or up to 40% lower power1 for data center, NFV and networking, and edge compute applications.
For more technical information about the Terasic DE10-Agilex Accelerator Board or to order the product, please contact Terasic directly.
Notices and Disclaimers
1 This comparison based on Intel® Agilex™ FPGA and SoC family vs. Intel® Stratix® 10 FPGA using simulation results and is subject to change.
This document contains information on products, services and/or processes in development. All information provided here is subject to change without notice. Contact your Intel representative to obtain the latest forecast, schedule, specifications, and roadmaps.
Intel technologies may require enabled hardware, software or service activation.
No product or component can be absolutely secure.
Your costs and results may vary.
Intel does not control or audit third-party data. You should consult other sources to evaluate accuracy.
© Intel Corporation. Intel, the Intel logo, and other Intel marks are trademarks of Intel Corporation or its subsidiaries. Other names and brands may be claimed as the property of others.
Published 6 years ago
Version 1.0sleibson
Joined March 17, 2021
Blog
Connect with experts on FPGAs and Programmable Solutions
