The BittWare IA-840F FPGA Accelerator PCIe Card bristles with high-performance I/O capabilities including two QSFP-DD optical cages (together capable of supporting four 100G Ethernet ports), a PCIe Gen4 x16 host interface, and three MCIO expansion ports for diverse applications. The MCIO ports can be used for high-bandwidth, low-latency, board-to-board communications or for high-speed connections to peripheral devices such as NVMe storage. The board also incorporates three memory DIMM sockets that together can accommodate as much as 384 Gbytes of DDR4 SDRAM.
These multiple, high-speed I/O and memory capabilities directly stem from an on-board Intel® Agilex™ FPGA, which also equips the board with a large amount of programmable logic – nearly 2.7 million programmable logic elements. You can develop and deploy high-speed hardware accelerators for a wide range of computing workloads using the Intel Agilex FPGA’s programmable logic and a variety of Intel® FPGA design and workload development tools.
“The IA-840F ensures that customers can quickly and easily exploit the advanced features of the Intel Agilex FPGA. For those customers who prefer to develop FPGA applications at an abstracted level, we are including support for oneAPI. This new unified software programming environment allows customers to program the Intel Agilex FPGA from a single code base with native high-level language performance across architectures.” said Craig Petrie, vice president of marketing for BittWare.
Additionally, BittWare has developed an HDL developer toolkit for the IA-840F FPGA Accelerator PCIe Card, which consists of an API, PCIe drivers, application example designs, and a diagnostic self-test.
The BittWare IA-840F FPGA Accelerator PCIe Card is based on an Intel® Agilex™ FPGA
BittWare has scheduled the first IA-840F card shipments for Q2 2021. Customers can also purchase the new accelerator card pre-integrated into a BittWare TeraBox server sourced through either Dell Technologies or Hewlett Packard Enterprise. (For more information about the BittWare TeraBox server, see “1U TeraBox 1400B Server From BittWare Holds Four FPGA Acceleration Cared, Two Intel® Xeon Scalable Processors.”)
For more information about the IA-840F FPGA Accelerator Card and TeraBox servers, please contact BittWare directly.
Notices & Disclaimers
Intel technologies may require enabled hardware, software or service activation.
No product or component can be absolutely secure.
Your costs and results may vary.
Intel does not control or audit third-party data. You should consult other sources to evaluate accuracy.
© Intel Corporation. Intel, the Intel logo, and other Intel marks are trademarks of Intel Corporation or its subsidiaries. Other names and brands may be claimed as the property of others.
Published 5 years ago
Version 1.0sleibson
Joined March 17, 2021
Blog
Connect with experts on FPGAs and Programmable Solutions
