Blog Post
Blog
2 MIN READ
Beyond Traditional Mid-Range: The Agilex® 5 Approach
sophiagoldsberry2's avatar
6 months ago
The traditional definition of a mid-range FPGA was largely based on logic density, referring to devices positioned between low-cost and high-end solutions in terms of capacity. That definition no longer reflects how modern systems are built.
Today’s embedded and edge applications place new demands on the platform. Performance is no longer just about gates, it’s about how efficiently data is processed, moved, and secured. These systems require tight integration of compute, memory, connectivity, and security, along with predictable performance, all within strict power and form factor constraints.
A New Definition of Mid-Range
Mid-range FPGAs are now defined by system-level capability rather than fabric size alone. Designers are looking for platforms that can integrate multiple functions, processing, acceleration, memory interfaces, and connectivity into a single device while maintaining efficiency and simplicity.
This shift is driven by workloads such as AI inference, video processing, wireless infrastructure, and real-time analytics, where latency, bandwidth, and integration matter as much as raw compute.
How Agilex® 5 Fits This Evolution
The Agilex 5 family is designed around this expanded definition of mid-range.
It brings together high-performance FPGA fabric, AI Tensor Blocks, embedded processor subsystems, modern memory support, and high-speed connectivity into a unified platform. This level of integration enables more efficient system-level design, reducing the need for external components and simplifying overall architecture.
In addition, Agilex 5 incorporates advanced security capabilities, including post-quantum cryptography support, enabling long-term protection for systems deployed in critical environments.
Agilex 5 supports the full spectrum of mid-range requirements, from power- and size-constrained embedded systems to more demanding data-intensive applications while maintaining a consistent architecture and tool flow.
Pushing the Boundary with Agilex 5 D-Series
At the upper end of the family, Agilex 5 D-Series extends the definition of mid-range even further.
With densities up to 1.6 million logic elements, combined with even higher-bandwidth memory, further enhanced AI acceleration, and faster, richer connectivity, D-Series extends the spectrum of mid-range to a new level. It provides the scale needed for complex, high-throughput applications, enabling many workloads traditionally associated with high-end FPGAs to be implemented within a mid-range platform.
The result is a platform that brings high-end capability into the mid-range category from a practical system perspective delivering performance, integration, and security without the cost and complexity of moving to infrastructure-class devices.
👉Click here to learn more about Agilex 5 D-Series
👉 Read the The New Scope of Mid-Range FPGA Designs Solution Brief
Updated 5 months ago
Version 3.0
