fpga ai suite
2 TopicsSpatial Architecture Boosts Edge AI Inference on Altera FPGAs
Edge AI needs to meet stringent size, weight, and power requirements while also satisfying deterministic latency for high levels of safety needed by physical AI systems that interact with humans and machines alike. Validation of accuracy and flexible placement of highly optimized inference pipelines needs multiple approaches. Altera addresses this need with its latest release of FPGA AI Suite software (2026.1.1), that introduces a spatial compilation mode. This mode generates dedicated per-model RTL through which the AI inference inputs streams, lowering latency, significantly reducing the delays, and improving safety in the physical AI chain; sense-think-act. Release 2026.1.1 also unlocks further improvements: Scales the AI IP to handle more complex/larger sequential mode inferencing (up to 500k ALMs) for overlay instances Increases memory bandwidth by utilizing multiple memory interfaces Easily explore more design options with architecture optimizer support for two new modes: multi-lane (achieving higher performance) and DDR-free (reducing latency by keeping all memory use within the FPGA). Reminder: Sequential mode is where a fixed overlay with precompiled microcode sequentially processes the inference model layers Other key highlights in software-based model evaluation include multi-core software emulation and RTL simulation for both IP types. Models targeting the FPGA’s Arm Hard Processor SoC Subsystem (HPS)-based host can now be compiled directly from an x86 machine via a Docker-based Arm emulator, with no physical Arm processor required. This further accelerates time to market with pre-silicon validation earlier in the design cycle. Spatial IP Compiler: AI Inference for the Physical AI Era Prior FPGA AI Suite releases compiled models into sequential IP, a configurable overlay architecture, analogous to a soft processor, where control logic orchestrates a parameterized datapath through microcode delivered via a configuration network. The overlay is flexible: one bitstream can run different models by loading new microcode and weights. This generality carries overhead; the microcode control layer, configuration decoding, and runtime scheduling all consume more FPGA resources and impact latency that a fixed-function design would not need. The spatial compiler takes a different approach. Instead of programming a general-purpose overlay, it generates dedicated RTL where individual model layers map to optimized library blocks and inter-layer connections become physical communication channels in the FPGA’s logic fabric. There is no microcode, no overlay control layer. For suitable workloads, especially smaller networks, this yields higher throughput at lower power with deterministic per-layer latency. For example, an internal MLP benchmark (two fully connected layers with batch normalization, tanh on a hidden layer, linear on the output, 8,000 trainable parameters, total of 52 neurons) shows the advantage of spatial: Targeting spatial results in the FPGA IP using 6K ALMs operating at 3.09 million Inferences per second with 28x lower latency versus Targeting sequential results in 28K ALMs, running at 0.11 million inferences per second. More new features include: Weights can be embedded in an FPGA’s logic fabric as part of the configuration bitstream via .mif initialization to achieve lower latency operation or streamed to the IP at runtime if model switching is required. A hostless DDR-free design example on Altera’s Agilex® 5 E-Series Modular Dev. Kit demonstrates the full flow from compilation through JTAG-based inference on hardware, with bit-accurate simulation for pre-silicon validation. Architecture Optimizer: Multi-Lane and DDR-Free Search Two deployment modes that previously required manual configuration are now searchable by the optimizer. Multi-lane execution and DDR-free architectures (all weights stored in on-chip M20K FPGA memory blocks) can now be swept automatically alongside other parameters, eliminating manual architecture exploration for these modes. Performance: 500k ALMs, Multi-External Memory, Burst Optimization FPGA AI Suite IP is now validated to 500,000 Adaptive Logic Modules (ALMs), up from 225k, unlocking larger Agilex 7 and Stratix 10 devices for maximum-throughput overlay configurations. Multi-External memory interface support lets a single FPGA AI Suite IP instance use two or more memory interfaces for higher aggregate DDR bandwidth. AXI burst size optimization improves effective throughput when multiple IP modules share memory, reducing latency and power with no RTL changes. Emulation, Simulation, and ARM Cross-Compilation Multi-core software emulation parallelizes the bit-accurate emulation kernel across CPU cores, making regression testing and quantization sweeps practical before hardware is available. The emulation model remains bit-exact with hardware output. RTL simulation now supports both sequential and spatial IP via Questa*-Altera FPGA Edition and VCS simulation software, enabling pre-silicon verification for both architecture types. A new --arm compiler flag enables ARM HPS model compilation from x86 via a Docker-based Arm emulator. The compilation targets SoC deployments where subgraph layers execute on the Arm CPU, no physical Arm hardware or Yocto cross-compilation required. Try It Now Once downloaded, no license or purchase is required for up to 100,000 consecutive inferences. Download the software or browse the handbook at FPGA AI Suite - AI Inference Development Platform | Altera1.3KViews1like0Comments[FREE WEBINAR] “ASK AN EXPERT: USING THE INTEL® FPGA AI SUITE”, JULY 27
Are you curious about how FPGAs can be leveraged for artificial intelligence (AI) inference and what tools are available to speed up the AI development process with FPGAs? Intel is holding an “Ask an Expert Webinar” on Thursday, July 27 at 9:00AM PDT to answer all your questions about the Intel® FPGA AI Suite and the latest innovations.2.6KViews0likes0Comments
