Knowledge Base Article
Why might the PCI Express signal detect feature fail at low temperatures on Arria® V GT and ST devices, and the link fails to train?
Description
Due to an incorrect receiver common mode voltage (Rx Vcm) setting in Quartus® II software version 14.0 and earlier, the PCI Express® signal detect feature may fail at low temperatures on Arria® V GT and ST devices, and the link fails to train.
The table below shows the Arria® device VCCR_GXB and Rx Vcm requirements.
DeviceVCCR_GXB VoltageRx Vcm Voltage
Arria V GX, SX1.1V/1.15V0.65V
Arria V GT, ST1.2V0.75V
Resolution
To work around this problem in Arria® V GT and ST devices, you can download and install the patch below and add the following Quartus® II Settings File (QSF) assignment for all PCI Express receiver channels in your design.
set_instance_assignment -name XCVR_RX_COMMON_MODE_VOLTAGE VTT_0P75V -to <pin_name>
You must make the above assignment to all PCI Express receiver pins in your design, and you should not use wildcard characters (*) in your assignments.
This problem has already been fixed in the Quartus® II software version 15.0.
Updated 4 months ago
Version 4.0
