Knowledge Base Article
Why is the Scaler II IP core unable to generate a mif file that is equivalent to the custom coefficient?
Description
You may encounter this problem if you incorrectly specify the names of the vertical coefficient file, or horizontal coefficient file, in the Scaler II IP’s GUI.
Resolution
To work around this problem, please supply a CSV file containing custom coefficient and enter the file name (including full path and .csv) in the Scaler II IP’s GUI.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
