Knowledge Base Article
Why is the captured register waveform in SignalTap II Logic Analyzer inverted from the expected signal value?
Description
You may see this behavior when you tap post-fit nodes in the SignalTap™ Logic Analyzer if the register has been implemented with NOT gate push back. This is the correct behavior.
Resolution
To avoid this behavior, tap the pre-synthesis register instead.
Updated 2 months ago
